Nine8SST
- May 19, 2011
- 23
- 0
- 1998 SS/T
- Magnum 5.9
Ok, so I just installed a Viper Responder 350 in my truck, 1998 Ram with factory keyless entry. Everything works perfect except for the power unlock. I wired up with the CHRYSLER 3/5 wire Door Locking Relay System, unlock is a 5 wire relay, and lock is a 3 wire relay. I split the unlock in the driver's kick panel. I am wondering if the split between switch/motor needs to be in the driver door? Literally between the switch and motor? I would totally appreciate any insight on this before I start backtracking. Thanks alot!!!!
-Jason
-Jason
