I've been trying to isolate an electrical issue on a 1994 1500 with the small V8 for about a month. It's a family truck we use for everything from moving the boats around to scuba to letting the neighbors borrow it for runs to Home Depot, etc.
A couple years back a mouse had gotten under the hood and chewed up some of the wires around the fuse box and in the main harness running parallel to the driver's side fender rail. At the time my father fixed it with heat-shrink crimps. It wasn't the best job but it was mostly ground wires. After his fix everything worked fine for years.
A few months back the tail lights started acting up. I'll list what's happening but its something between the driver's side blinker and the reverse lights that I can't find for the life of me. When this happened I tore out his old repairs thinking that was the cause. No luck... I have now replaced or laid my hands on every inch of wires (outside the cab) on the truck. All soldered properly, replaced with proper color and gauge wire and I used heat shrink tubes so it's sealed properly.
So:
WITH THE RUNNING LIGHTS OFF:
The right blinker and brake light work fine
The right backup light works fine
When the LEFT blinker is used BOTH reverse light filaments are just barely orange and turn on and off WITH THE PATTERN OF THE BLINKER
The LEFT brake light causes the same thing, both reverse filaments are amber
WITH THE RUNNING LIGHTS ON:
The Right side of the truck seems to be fine with the lights on or off. (meaning brake light, running light and blinker work fine)
The LEFT blinker initiates an alternating flash pattern between the left blinker and BOTH reverse lights.
When the left brake light turns on it's dim and both reverse lights are very bright.
Any thoughts, suggestions or ideas? The only thing I really haven't checked is the reverse light switch (if that's on the transmission or on the column). I've also not gotten into the cab (behind the dash) of the truck at all. I have a hard time believing it's behind the dash since nothing has been touched under there - but sho knows. Can you guys point me to a place where I should look to find a place where the reverse lights, the left blinker and the left brake light would all come together?
It looks fine and I'm getting frustrated. Inspection isn't until November so we have time... but it's just a pain and only a matter of time until they stop issuing warnings and start giving fix-it tickets.
Thanks.
So:
Thanks.
