Lets see your sub boxes!!
the codes
the codes
Houston, Tx
Magnum 5.2
yeah crutchfield has a TON of info lol
Tapatalk Addict
crowellalex
Magnum 5.9
Its getting there. Sub and amp are arriving at work tomorrow.
the codes
the codes
Houston, Tx
Magnum 5.2
nice man, here's mine. going in maybe Thursday, amp is in, just gotta get home to do it.
Tapatalk Addict
01RAMJACKED
eugene oregon
Nice work guys its pretty easy to figure it all out, I build custom boxes for cars trucks suvs etc, ill post some epics tomorrow I have a Boston g3 in my 01 ex cab custom box I built hits 127 db ported to 24 Hz makes the truck shake and the windshield wipers skip if I have it bumping hard, I shattered my windshield in my integra with a box I built
Born,raised and currently reside in eastern Ohio
1999 quad cab sport 4x4
5.9 Magnum=360CI
tsg2009
Smyrna, De
5.9 magnum
you should be good, i have an extended cab with one like that under my back seat, it should all be ok unless you have a tray under ur seat, double check your height though
98ramready
Buchanan VA
5.2 magnum
I have a 98 single cab and want some bump too but don't know what size the box should be for 1-10" sub. I want to build one but I need some input on size and port/sealed
Any advice will be greatly appreciated.
Happ!
Whered you mount the amp for that probox?
the codes
the codes
Houston, Tx
Magnum 5.2
under my seat. drivers. ran the wire through the dash and kick panel under the carpet and underneath my seat
Tapatalk Addict
BlackMagnum2000
Locust Grove, GA
5.9 Magnum
Probox that was in it when I got the truck. This subs could hit so much harder if they had a little more air flow. Two Rockford Fosgate 10" Punch series. I'll be upgrading to two 10" power series before long. Just upgraded my amp to a 1800 watt monoblock class D Kenwood. Great amp.
dapepper9
Iowa/Nebraska Border
5.9L V8
what are you guys opinons on the subthump.com box, its only $169 and it fits dual 10s or 12s (shallow). It's basically exactly what I've been lookin for but not sure if its a good idea. Gotta sink some cash into the plenum but thinkin bout audio afterward
bloombloom88
Plano, Texas
I know this is a 2nd gen thread.. But it might give guys an idea or two. Here's my box
Custom built sealed fiberglass box with 2 10s I believe the total airspace is 1.5 cubic feet
No members online now.
BGW656
