new direction, need advice
the codes
Houston, Tx
Magnum 5.2
so I am going in a new direction with my system, gonna return my 2 twelves and get either a JBL or infinity 8". gonna be a great fit for me. I need to know..will a 1000 watt 2 channel bridge able amp blow a 800w peak sub? or will it run it fine? what about a 1000w peak sub?
thanks, learning all this audio stuff still
the codes
the codes
Houston, Tx
Magnum 5.2
haha gotta have some bump in the trunk bro!
jhemi
wisconsin
peak power doesnt mean much its all about the rms, amp depends on brand, alot of amps dont do rated power, and depending on box sumtimes you cant run full rms to the subs with out them bottoming out, so to answer question 1000 watt amp will work with 800 or 1000 watt sub just set the gains right and you will be fine
the codes
the codes
Houston, Tx
Magnum 5.2
oh okay great I was just worried I was gonna under power my sub and it was gonna die.
the codes
the codes
Houston, Tx
Magnum 5.2
amp is 50w x2 at 4 ohms and 75w x 2 at 2 ohms and I will have to double check but I think the sub was 250w rms max
jhemi
wisconsin
under power a sub doesnt hurt the sub, its using a too small amp and cranking it all the way up so it clips that burns the sub up, as long as the power is clean you are fine thats why its better to use a bigger amp and keep it turned down then you get true rms that is clean power to the sub
the codes
the codes
Houston, Tx
Magnum 5.2
ahhh okay that's what iv been looking to hear. so how can I wire a svc for 2 ohms?
jhemi
wisconsin
you cant but you could wire both subs together to make 2ohms and bridge your amp
the codes
the codes
Houston, Tx
Magnum 5.2
damn I was only planning on getting one really good 8 and putting it in the center of my backseat
the codes
the codes
Houston, Tx
Magnum 5.2
are 2 ohm 8s hard to find? might just squeeze two 4 ohm 8s... are 4 ohm dvc hard to find? would a dvc sound better?
jhemi
wisconsin
dvc doesnt sound any different just gives you different wiring options, if you got the money check out dc audio they got the best 8" subs around expensive but worth the money but not that familure with 8s in general, google is your friend
the codes
the codes
Houston, Tx
Magnum 5.2
alright thanks man you've been real helpful, think I know what I'm gonna do now
ChloeBrooks
