Go Back   DODGE RAM FORUM - Dodge Truck Forums > Dodge Ram Generations Forum > 2nd Gen : 1994 - 2002 > Audio & Electronics
Audio & Electronics
Specific question about infinity rewire
This is a discussion on Specific question about infinity rewire within the Audio & Electronics forums, part of the 2nd Gen : 1994 - 2002 category!
OK guys so I had installed new head unit and speakers well I'm a little disappointed with the sound quality ...
Like Tree1Likes
  • 1 Post By dudeman2009
Reply
Old 08-15-2016, 07:51 PM   #1 (permalink)
esiegel91's Avatar
Ram Year: 2001
Engine: 360 v8
Default Specific question about infinity rewire
OK guys so I had installed new head unit and speakers well I'm a little disappointed with the sound quality due to rewireing the infinity amps on the aftermarket speakers. So I'm trying to rewire the head unit straight to all the speakers. Is this the right way to do it. Just straight from the head unit to the speakers?
Sponsored Ad
Register to remove this ad.
esiegel91 is offline   Reply With Quote
Old 08-16-2016, 01:18 AM   #2 (permalink)
Ram Year: 2001 1500 Sport with enough electrical modifications to make your head spin
Engine: Magnum 360
Default
Yes, go straight from the speaker out wires from the radio harness to the speakers, ensure than positive goes to positive and ground to ground. Also, make sure you get the correct pairs together, the factory wiring is kind of strange.
Old 08-18-2016, 01:04 AM   #3 (permalink)
esiegel91's Avatar
Ram Year: 2001
Engine: 360 v8
Default
So rather than splicing into the metra radio harness, I'm splicing into the Dodge harness. Is that what I'm gathering?
Old 08-18-2016, 09:57 AM   #4 (permalink)
Engine: Magnum 360
Default
It depends on what you want to do. You are changing it from factory at this point, so its up to you where you want that change to be. My personal opinion is to leave the factory connectors alone, just use the adaptor. In the case that you are running your own wire to the speakers, splice into the metra harness and leave the dodge harness stock. Everything is better in the long run (repair wise) stock.
What I would do, is goto the door panel speakers where all the speaker hookups are, and bypass the amp. Using the wire in the door that originally went to the amp, just hook it straight to the speaker.
Ex. On the front left door. The wires coming from the radio for the front left door speaker, will be dark green+ and brown/red-. You would hook those two wires directly to your front left door speaker (splice in the front left tweeter as well, it will work just fine)
For the rear left speaker, you would take the brown/light blue- and brown/yellow+ in the front left door and splice them into the (4 Door) brown/light blue- and brown/yellow+ (2 Door) white/dark green- and white/violet+.
That way you don't dink around with the factory dash harness, and any time you want to remove your radio to sell the truck, you can go buy a cheap $40 bit with the adapter, and plug it right in no problem. Since you have the infinity system and are removing the amps, do not hook up the light green wire on the factory harness. Do not cut the factory harness, just cut the metra harness if it does infact power that wire. Otherwise the case may arise down the road that the now disconnected wire hanging in the door shorts to ground and blows the fuse.
V10so_utah likes this.
Old 08-19-2016, 01:37 PM   #5 (permalink)
esiegel91's Avatar
Ram Year: 2001
Engine: 360 v8
Default
Awesome thanks man! I'm doing it tonight
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
another infinity audio question headhunter123 Audio & Electronics 8 04-16-2015 07:20 AM
Question on specific bolt for CAI Warl Engine & Performance 1 03-27-2015 01:42 PM
Need to rewire - do it myself or take it to a shop? Yoox_II Audio & Electronics 4 12-13-2014 07:22 PM
Infinity question cwakefld Audio & Electronics 7 01-11-2012 04:49 PM
Factory Infinity Question shinglelayer Audio & Electronics 6 09-08-2011 09:28 AM
GM Truck Forum
Ford Raptor Forum
Chevy Tahoe Forum
Chevy Cobalt Forum
Chevy Camaro Forum
Toyota FJ Cruiser Forum
Ford Truck Forum
88-98 GM Truck Forum
73-87 Gm Truck Forum
Ford Expedition Forum
Chevy Equinox Forum
Chevy Cruze Forum
Jeep Liberty Forum
Jeep Forum
Dodge Ram SRT10 Forum
Chrysler 200 Forum
Scion xD Forum
Scion xB Forum
Dodge Challenger Forum
SRT Forum
Nissan Titan Forum
Buick Enclave Forum
Cadillac Forum
Cadillac XTS Forum
