is it bad to drive on 4wd hi mode...
'01 Ram
what are your opinions. remember, i'm on 35's so i want to make sure that i'm not going to hurt or damage anything. thanks.
05singlecabHEMI
Lilburn,GA
i hear its not good for dry pavement, but if its wet or any weather its fine. i dont get it but thats what i heard lol.
schroederMP
Indiana
Cummins
You DONT want to use 4wd unless you have to (mud, snow, sand, ect)
Driving around in 4wd on dry pavement or non slick pavement will tear up your front suspension.
HKkid
Missouri
DO NOT do this. Good way to tear stuff up. Only time you should engage 4wd is when there is slipping.
txbass06
NE Texas
5.9 Magnum
I wouldn't do it. That's a good way to bind something up and break an axle joint of shaft
Stangshcky12
Oshkosh, WI
5.9 Cummins
As long as you dont turn. Even driving straight on dry surface probably isnt good
When you turn in 4wd your tires turn on different radius which cause the binding. This is the same reason some have a little bit of wheel hop when the have lockers in the back
zack
pa
2004.5 packing the smarty
5.9 cummins ho
Driving in fwd is not going to hurt it ....if I run some one around town light to light I will lock mine in fwd you will launch like a rocket ship
schroederMP
Indiana
Cummins
Do you straight launch in 4wd wont hurt.... but driving around, making turns will.
zack
pa
5.9 cummins ho
Yea^^^ straight line race then kickit back it twd other wise I will smoke the tires taking off
quietpeen
2021 TRX
Hellcat
yup, its def not good to just drive around with it engaged, unless the roads are covered with snow
nussdawg395
PA
5.9 Magnum
Yupp what they said. Unless you want to replace tires, all your front suspension and drive parts, kill mpgs, and have a crappy ride.
Badger
Bettendorf, IA
Some states don't salt. So they act as sort of a paddle to push in the snow. I wish my state wouldn't salt, they have been using the liquid stuff for the last few years and that stuff eats metal worse than the solid stuff.
Muddytazz
Salem, Or
2013 Ram 2500HD 4x4
Hemi baby
Salting the road here in Oregon is illegal which I like.....no rust. We use a bio-degradable anti-freeze/something else mixture on the roads/ice
Stangshcky12
Oshkosh, WI
5.9 Cummins
My buddies use chains sometimes just for the hell of it
You would be suprised to difference they made
zack
pa
5.9 cummins ho
