diverjer
My Ram 1500 has 166,000 and I am sure the fluid has never been changed. I bought this truck on Oct 2 and for the most part all is running good. Trans is a little slow shifting when cold. Changed oil and filter. Changed Dist cap, rotor, plugs and wires. I am positive they were the originals. Also, spent time cleaning throttle body, it was nasty.
I am thinking of just dropping the tran pan, put in new filter, adjust rear bands, clean pan and reassemble. Also adjust front bands which can be done easy enough.
Then it has been mention I should go get a power flush, which I understand gets all the fluid replaced. But it seems to me it will also circulate a lot of gunk around that would normally not be traveling around in the transmission. That could cause problems.
Question is should a filter, clean pan and band adjustment be enough or is there a compelling reason to have a flush done?
