Hey guys, this is my first post and I'm in need of some advice.
I have a 2001 Dodge Ram with the 5.9L and my heater doesn't work well at all. My temp gauge sits in between 130 and 210 which seems low to me. I just changed the thermostat tonight and it did nothing for me. After I was done, I went to go burp the system and noticed the radiator cap wasn't even hot, and the lower radiator hose had pieces of ice in it.. I'm up here in Maine and it was about 17 degrees F today. The upper radiator hose was hot though. Do you think I have too much water in the antifreeze mix which is causing my heater to suffer from insufficient coolant flow? I also noticed some gurgling coming from under my dash and I'm pretty sure that's from the heater core. What should I do?
Any help would be appreciated!!
-Hauzer
-Hauzer
