Need advice on tranny problem
Stj0482
5.9 magnum
Got a 2000 ram 1500 I believe it's got a 46re. The problem is when I stomp on the fuel there no overdrive. Everything else seems fine as far as shifting is concerned it seem anyway. Anyone have any experiences like this. Advice please guys
Thanks in advance.
Mopar1973Man
New Meadows, Idaho
Read the error codes it might give a clue on what might be the problem with the trans. Might be a relay or solenoid but it best to get the code so you not guessin'
S
Stj0482
5.9 magnum
No codes showing up that's the problem
HemiBabe
DFW
Hmm... Might be a sign that it's about to mess up entirely.
S
Stj0482
5.9 magnum
Not sure what your trying to tell me ghostram
Joshwaa
Lake Worth, FL
2016 CC 4x4 Laramie AirRide
What do you mean no overdrive? If you stomp on the gas its not going to go into overdrive. That's for crusing. Are you trying to say it wont downshift when u stomp on it?
S
Stj0482
5.9 magnum
Ya that's what I mean when I'm cruising along
Joshwaa
Lake Worth, FL
You should only feel the tranny shift 3 times then you should feel the converter locking up.
Are you not feeling the 3rd shift or the lockup?
S
Stj0482
5.9 magnum
When I'm cruising down the highway and wanna pass another vehicle and give her the fuel it's like it goes into neutral there nothing there
Joshwaa
Lake Worth, FL
Check your tranny fluid level wile running in neutral. Start there. I am pretty sure that you tranny is all electronic so I doubt it vacuum related. If you floor the gas from a stop do you ever feel it slip?
S
Stj0482
5.9 magnum
Fluids good and nope no slip from a dead stop
Fryekenn
