Go Back   DODGE RAM FORUM - Dodge Truck Forums > Dodge Ram Generations Forum > 2nd Gen : 1994 - 2002 > Tech Info
Sponsored Ads
Register to remove these ads.
Tech Info
noob to dodge differential fluid ?
This is a discussion on noob to dodge differential fluid ? within the Tech Info forums, part of the 2nd Gen : 1994 - 2002 category!
Register to remove these ads. It's free! Originally Posted by Mopar1973Man How about FREE and a full Factory Service Manual??? ...
Reply
Old 12-04-2011, 08:26 PM   #11 (permalink)
V-10 RAM's Avatar
Ram Year: 1999
Engine: v-10
Smile
Download PDF Dodge Ram 2001 Service Manual | PDFTown.com
I'm using Mobile One 80w-90 GL-5 lubricants for the last 190K miles with zero issues... Change fluids every 30K.
DESCRIPTION
A multi-purpose, hypoid gear lubricant which conforms to the following specifications should be used. Mopar Hypoid Gear Lubricant conforms to all of
these specifications. SAE ratings also apply to multiple grade gear lubricants. In addition, API classification defines the lubricants usage.
FRONT AXLE
² The lubricant should have MIL-L-2105C and API GL 5 quality specifications.
² Lubricant is SAE 75W-140 SYNTHETIC gear lubricant.
REAR AXLE
² Lubricant is a thermally stable SAE 80W-90 gear lubricant.
² Lubricant for axles intended for heavy-duty or trailer tow use is SAE 75W-140 SYNTHETIC gear lubricant.
NOTE: Trac-lokY and Vari-lokY equipped axles require a friction modifier be added to the lubricant.
CAUTION: If axle is submerged in water, lubricant must be replaced immediately to avoid possible premature axle failure.
That works too. I like to have mine in book form so I can drag it out no matter were I'm. I have had to use mine in the middle of the desert 70 miles or more from anything were a cellphone was only good for throwing.
V-10 RAM is offline   Reply With Quote
Old 12-04-2011, 08:49 PM   #12 (permalink)
Mopar1973Man's Avatar
Cummins Diesel Section Mod
Ram Year: 1996, 2002
Engine: 1996 Dodge 1500 (V8-5.9L) & 2002 Dodge Ram 2500 (5.9L Cummins)
Default
That's a rather large book at over 2,900+ pages if I remember correctly. I hardly doubt you keep that big arse book in the truck...
I'm also living in a area where a cellphone is worthless too. Home is just over the second ridge...
http://i52.tinypic.com/28vese1.jpg
__________________
Michael Nelson - RamForum.com Cummins Moderator
2002 Dodge Ram 2500 Cummins - Mod List ~+~ Pulling 2000 Jayco Eagle 296 FBS ~+~ 1996 Dodge Ram 1500 5.9L V8 - Mod List
Mopar1973Man is offline   Reply With Quote
Old 01-06-2012, 10:42 PM   #13 (permalink)
JeffBeck's Avatar
Ram Year: 2004
Engine: Hemi 5.7
Default
Hello, I have a related question... I just bought a 2004 Quad Cab wit 206,624 miles on it. It needs lots of TLC. I think I will change the Differential fluid front and back. My Son sings praises about Lucas products, may go with those. I still have to figure out if I have a Limited slip or not. Any advice on that would be great. I decoded the VIN..Its not there. I also am wondering how much fluid I might need to buy to do the job.
JeffBeck is offline   Reply With Quote
Old 01-07-2012, 10:47 AM   #14 (permalink)
Default
Hmmm... I think it going to be right around 1 gallon for the rear diff. at least my 02 Dodge is...
__________________
Reply
Bookmarks
Tags
changing diff fluid, dodge ram fluid, ram diff fluid
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
DIY: Differential Fluid Change OlDirtyJohn 3rd Gen DIY 10 03-07-2012 01:44 AM
differential fluid? 05singlecabHEMI General Discussions 4 08-13-2011 01:15 PM
Locking Differential?... Not exactly! Trupiano The Lounge 17 01-15-2011 07:47 AM
Differential opinions glass3222 General Discussions 10 10-10-2010 08:40 PM
Front Differential with pix!! rocket General Discussions 25 08-22-2010 09:10 PM
Fully Driven Auto Network
GM Truck Forum
Ford Raptor Forum
Chevy Tahoe Forum
Chevy Cobalt Forum
Chevy Camaro Forum
Toyota FJ Cruiser Forum
Ford Truck Forum
88-98 GM Truck Forum
73-87 Gm Truck Forum
Ford Expedition Forum
Chevy Equinox Forum
Chevy Cruze Forum
Jeep Liberty Forum
Jeep Forum
Dodge Ram SRT10 Forum
Chrysler 200 Forum
Scion xD Forum
Scion xB Forum
Dodge Challenger Forum
SRT Forum
Nissan Titan Forum
Buick Enclave Forum
Cadillac Forum
Cadillac XTS Forum
