Oil pressure Dropping?
Justin_R
i have a 99 ram with A 318 and everytime i let off the gas my oil pressure drops all the way to 0. Also, when i am driving, my oil pressure is only at about 30 psi. i already replaced my oil pressure sending unit and oil pump. any ideas what could cause this?
thanks
Okiespaniel
Work, Shop, Computer
magnum, 5.9
Does this happen once the engine is warm?
Main/and or rod bearings are wearing thin. No...they won't knock, yet :)
J
Justin_R
It does weather it's warm or cold and with that many miles worn bearings does make sense... Thanks
Redtruck-VA
Virginia
2003 & 1989 D250 RWD
I would think the oil pressure would indicate higher when cold settling down as it warms up. Regardless I would connect a mechanical gage to the engine to determine if it matched the factory gage or not.
ChloeBrooks
