p1740 - where to start?
rambob
LA/MS
318 5.2l
just got the CEL at lunch. I didn't notice any change in shifting or anything. just looked down at the red light and saw the light. went to Advance and got the code read.
NOW WHAT??
SYMPTOM
P1740-TCC O/D SOL PERFORMANCE
WHEN MONITORED
The Torque Convertor Clutch (TCC) and Overdrive Clutch (O/D) will be tested each time the PCM requests TCC engagement in 3rd gear and O/D.
SET CONDITION
The code will set if the expected RPM drop is not achieved while attempting to engage TCC or O/D. This indicates a malfunctioning torque convertor or overdrive clutch.
POSSIBLE CAUSES
Camshaft DTC Present
Engine RPM DTC present
Fuel level low
Misfire DTC present
Output speed DTC present
P1765 DTC present
Park/neutral DTC present
PTO engaged (if equipped)
Torque converter clutch DTC present
TPS DTC present
Transfer case in low range (if equipped)
Transmission relay DTC present
Transmission temperature too cold
Intermittent
Check transmission fluid-debris
Check transmission fluid-stall
3-4 shift solenoid
Oil pan contains excessive debris
Shaft or seal damage
TCC solenoid
Torque converter
ramhunter9
P-Star Jeep Wrangler
Crap
Sent from my SAMSUNG-SGH-I997 using Tapatalk
ramhunter9
Bob-o .. lets start here
Check the obvious first .. then I ask when was the last service done on the trans ?
rambob
rambob
LA/MS
318 5.2l
I checked the fluid level and color. Both are good. No burnt smell. I plan to check the electrical connections for something obvious. That was the cause with my dads 2gen. Everything feels normal. I was cruising 45 mph when it came up. Not towing. Normal conditions.
I plan to clear the code and see if it returns.
No idea on the last service. But the fluid looks good. I have plans to do it soon so maybe sooner than later.
wermbang
Iowa
2001 Off Road
5.9L V8 Sport
is it shifting into 3rd and OD?
I just went through that, changed the fluid and filter, and that worked for me I believe it was a clogged filter.
rambob
rambob
LA/MS
318 5.2l
yes.
thanks
from what I have read there are soo many thing it could be or have been.
just crossing my fingers
my dad used to work with a great trans guy. so worse case, I know I can get a deal on a rebuild or whatnot
rambob
rambob
LA/MS
318 5.2l
its back...
p1740 manufaturer control trans
I was not at all surprised to see it right after the last load of moving last night.
the bad part is I have to drive 3 hrs round trip this afternoon to buy a new dining room set.
so, next weekend = trans service
SMITHY
KANSAS CITY
2011 Dodge Ram Quad 4x4
4.7 Magnum
When I ran the transmission shop, we had alot of Dodge and Chrysler vehicles come in . On 80% of them it was a simple fix that did not require replacement. Find an honest shop and have them diagnose it. You cannot go by the Pcode alone and they have lap tops they utilize while driving the vehicle and can perform all sorts of diagnostic testing while driving it. They can engage the torque converter and test speed sensors, check fluid pressure and pressure of shifts. You name it. That would be what I would be doing. I can tell you this, the more you drive this way, you can be doing internal damage, if it is in fact not already present.
quietpeen
2021 TRX
Hellcat
I agree with smithy...a trip to a reputable trans shop might be your best bet.
rambob
rambob
LA/MS
318 5.2l
how much will a reputable shop charge me for this service? I'm strapped this month.
I could probably afford a fluid and filter change if I "diy". but the thing with that has been no time. after this weekend, I will have some time.
I had the same code 9-29 as I stated it was TCC and O/d wording. it went off on its own a few weeks ago.
no symptoms the first time.
this weekend I have been making a half dozen trips moving a household of crap.
there was a slight abnormal shift point once last night while pulling from a light. the CEL came on the next time I started the truck.
SMITHY
KANSAS CITY
4.7 Magnum
I know the shop that I ran, we did not charge for it, unless it took over an hour of diagnostic time. If over that, then we charged our regular hourly rate. Most of the time, with the right Diagnostician, it was wrapped up and they knew the problem.
rambob
rambob
LA/MS
318 5.2l
what is the product that does this detailed testing, so I can ask if the have it or not?
Ram5.9lover
5.9L Magnum
P1740 fix
Hey guys, so I may have gotten lucky with mine, a few times now. So this is the 2nd time this has happened to me: When I am driving down the period after an extended period of time my truck will pop a 1740 and drop out of OD on me. Had a tranny expert friend take a look the first time (2009) and it turned out it was a "speed sensor." Me, being a relatively experienced tech, (10K hours plus in a shop) thought he was screwing with me. Turns out he wasn't. I replaced it with the fluid and she worked like a dream. Happened again, couldn't get my old girl through emissions for 5 years, but didn't think it could possibly be that sensor again. Replaced it, without changing the fluid, and flew through emissions like she was fresh off the line. Just got the code again tonight....time to change the fluid. Something to look for, at least with mine, is that it was covered in metal shavings and theres no way that it could have gotten whatever reading it wanted to off it it. I would suggest there. Its on the drivers side, at 10 o'clock, towards the rear, if youre looking at it from the rear axle. Good luck guys, hopes this clears up a lot of sorrows and works for ya'll
dapepper9
Iowa/Nebraska Border
5.9L V8
Thx man! With that kind of shop experience you should stick around :roflsquared:
Myself and at least 2 others have dealt with this damn code as well. For me, my trans runs alright and now that it's warming up outside it's working better than it did 3-4 months ago. Kinda ****** me off cuz i have a built PATC sitting my parents garage waiting to go in and this hunk is shifting fine again. I've had that code nonstop since i got the truck 5 years ago. It's possible it's one of the 02 sensors or is directly tq converter related as the trans sensors are all new
ChloeBrooks
