I would think it would be in the factory service manual. Or is that where you've been looking?
I do not have one.
Been looking online.
Figure I'll cut circuit 2 wire at the switch and run a new wire to the brake lights.
Had a short. Now the brake light fuse blows when brake is pressed. Wires are all disconnected at the back of the vehicle. Switch cooked. Wires got hot. New switch works but just blows the fuse. Figured the issue is between the switch and the rear of the truck, so, I'ma run a new fukn wire.
Btw, at $10/ fuse I made my own jumper and use the cheap little spade fuses till this mess gets sorted.
