Steering Play and Ball Joint Problem!!
A
ama009
1998 Ram 1500
3.9 V6
Did you remember to tighten the nut down after adjusting the bolt??? the track bar is the long bar that goes across from wheel to wheel.
Oh yea. I made sure it was tight. The DIY section states to turn the screw 3/4 turns for 2" adjustment, but I had to turn it about 1 1/2 turns to get it to adjust. I'll have to check it again and see if it is working itself loose.
A
ama009
1998 Ram 1500
3.9 V6
Now, how do i know if the track bar has issues? is it going to be loose? wiggle?
Bigtman07
Registered User
Piqua, Ohio
Cummins 5.9
It may wiggle a bit but it shouldn't move like a ton.
dieseldays
hey guys my 6.7 just started having this "death wobble" and my friend said he thinks that one of these might work Dodge Steering Stabilizer
anybody have a second opinion on this ? thanks in advance :favorites13:
Goodie1990
