Sorry, but you should never use any sealer on a transmission gasket. You'll have to drop the pan to make sure that the lip isn't bent or warped. You can straighten it carefully.
Transmission fluid will cause a cork gasket to expand, that is why you don't use sealers. Rubber or solid style style gaskets can't absorb the sealer so it is a waste of time...it will shove the sealer out. You can use a few drops of super glue to hold the gasket in place until you get a few bolts started.
Retighten the pan to torque specs.
Either transmission pan filter kit you get from the parts store will have the gasket with the filter. And the directions said not to use rtv. So I didn't lol. It fit on the pan and bolted right up. But like stated above one of them was used up to years 95 and the other was used after that. I have a 98 and had to get the RH kit I believe I don't remember. I did mine yesterday morning so just trying to give you what I remember!
That's correct Zach...either use the gasket supplied, or RTV, but not both. So you did good.
