Transmittion overheat
Tony5.9
5.9 Magnum V8
My transmittion over heats after 30 min of driving what could that b and I just changed the trani fluid n filter n ima bout to replace the governor pressure selenoid and governor pressure sensor
Bigtman07
Registered User
Piqua, Ohio
Cummins 5.9
Is the light on the dash what is telling you the trans is overheating?
T
Tony5.9
5.9 Magnum V8
Yes n overdrive goes off n it stops shifting
T
Tony5.9
5.9 Magnum V8
Yes i thought that may b the problem but were can I get 1 n how do I replace it
T
Tony5.9
5.9 Magnum V8
Transmission overheat
The check valve is deleted but the trani still overheats granted it takes longer to overheat now that the check valve been removed
HolyRamBatman
Deep in the Heart of Texas
A stupid question or two.
Radiator coolant full?
Trans fluid full?
I have never heard of it but is it possible for the need to "burp" the system?
Tranny lines clogged?
smiley
Minot, ND
2014 Ram 2500 Crew
6.7L Cummins
What about replacing the trans cooler I believe the factory ones are notoriously undersized anyway or at the very least ineffective making an aftermarket one a good idea.
$miley
ChloeBrooks
