KansasRam1997
- Nov 24, 2015
- 25
- 6
- Lawrence, KS
- 1997
- 5.9L 360 Magnum
BIG SYMPTOMS/ISSUES: Non-stop drip of coolant coming from the water pump (weephole I believe), coolant temp. gauge rises w/o dropping down to normal operating temp. at idle.
Hi, my truck had a slight leak at the water pump, so i went ahead and bought a new one from O' reilly's, even though it wasn't overheating. The radiator was junk due to it being clogged up with rust and deposits from the previous owner that I bought it from. The entire cooling system is brand new with thermostat, water pump, radiator, hoses etc. and it still overheats. I tried using the special yellow funnel to purge the air and no luck! When it idles, the temp gauge just keeps going up until I have to shut it off around the 3/4 mark before it hits the redline. I'm starting to think O' reilly's sold me a junk water pump because everytime I put coolant in the radiator coolant tank, I can see coolant drip out of the weephole! Way more than normal. Honestly, my old rusted up water pump did a better job than this new junk I got at O' Reilly's.
Please let me know of any advice you might have. Thank you
