Help on a 2001 with 6 speed
gordfarr
cummings 5.9
I have a 2001 with a 6 speed. I had the dead pedle thing and took an injection pump off a 2000 with an auto tran. and put it on the truck it ran alright for a month. Now when i let off the throtle it throws me forward like no fuel it doesn't cut off though.
lilfroger
5.9 CTD
Check for codes (use the key and turn from off to run 3 times w/o starting ... they will show on the ODO even if the check engine light is not on). If the lift pump is going out you'll get a few different ones.
What did you replace it with? Stock or aftermarket?
Mopar1973Man
New Meadows, Idaho
First off there is only 2 reasons for dead pedal...
1. APPS Sensor
2. VP44 failure
APPS sensor will always throw a error code P0121, P0122 or P0123 with a dead pedal problem.
As for the VP44 it could be pure failure. This would be caused by lack of fuel pressure so I would check the fuel pressure of the lift pump. There is 2 numbers needed. Idle pressure and WOT pressure at highway speed.
So basically we need both error codes and fuel pressure numbers to tell you whats going on exactly.
