starting new project
ljvsnyder
s. Illinois
So I have decided to put a little color under the hood. Going to start by painting the egr crossover cover. Question for everyone, should i put primmer on or just adhesion promoter. The plastic is textured. The next part Will be to do the ccv cover and the valve cover.
LB3711
Trumbull, CT
3.6L V6
i would clean, prep it well then adhesion promoter then primer then paint.
Stangshcky12
Oshkosh, WI
5.9 Cummins
Either or, adhesion promoter is a primer
If you can put color on it within 10-15 minutes of the adhesion promoter then you don't need primer but if you don't plan on doing the color coat then you'll need a primer
ljvsnyder
ljvsnyder
s. Illinois
Well EGR crossover tube cover is complete, get some installed photos tomorrow. But for now here are some after completing the work.
Next up will be the air intake top. Then the CCV cover. The lettering on top will be the only issue I can think of.
ljvsnyder
ljvsnyder
s. Illinois
Well, couldn't wait till tomorrow to get it in. Can't wait to get the CCV done as well.
Definetly need to clean up under the hood, I am liking the way it is going to look.
ljvsnyder
ljvsnyder
s. Illinois
Just an update on the progress. Still need to paint the C and the words black, but comming along nicely.
And the fuse box cover.
Now i need a billet dipstick handle and oil cap, and other things to dress up the engine bay.
Wandell
Cummins 6.7
Looks good! Nice work!
ljvsnyder
ljvsnyder
s. Illinois
thanks, still got a ways to go with the under hood improvements. Want to tackle the airbox next and would like to get some nicer radiator hoses.
Manutea
Diamond Bar, CA
Definitely looks nice.
I did my air filter box, but wasnt brave enough to continue.
Now Im strongly reconsidering it ;)
Thanks
ljvsnyder
ljvsnyder
s. Illinois
I like the personal touch it gives the vehicle. Lets see a pic of your airbox. With the 4.7l you should have a nice big engine shroud to play with, post some pics when you are done. I have been using off the shelf touchup paint, may not be the best quality, but readily available.
ChloeBrooks
