Injectors ? Easy job or not
ramhunter9
P-Star Jeep Wrangler
Just curious on how hard this job is going to be or should I have it done .
I am by no means a diesel mechanic but I know the gas engine pretty well .
What all does this consist of ? I will be going from stock injectors to RV275 or +50's .
wermbang
Iowa
2001 Off Road
5.9L V8 Sport
Good info there.
ramhunter9
ramhunter9
Ya , I will hold the oem ones .
I just dont know if I want to go with the RV275'S OR the 50's
Everyone says 150's but I know better ..lol .. not till the new turbo is on and that aint happening anytime soon
KGBIGCOUNTRY
MECH, VA
2004 RCSB/2005 QCSB
Michael have you had any luck having a set scaled and flowed? Theres a local diesel shop that will do just about and diesel injectors for not alot of money.
Mopar1973Man
New Meadows, Idaho
No... Sorry... I don't have the stuff for doing that at all. For me its 2.5 hour ride to Lewiston, ID to a injection shop to get the stuff done.
ramhunter9
ramhunter9
Local shop wanted 300 bucks to install them . WTF
Still need to decide what ones to go with
Mopar1973Man
New Meadows, Idaho
Holy Cow...
Bring the truck here and half rack of beer I'll install them for ya... It's like changing spark plugs with a new twist...
ramhunter9
ramhunter9
LOL , it is kinda
I am going to do it , just worried about taking the fuel rails off and getting it all lined up with no leaks .
Mopar1973Man
New Meadows, Idaho
The whole trick is keeping everything clean and sealing problems should occur. So get a can of engine degreaser and wash the engine down good and trhen get working after it dries.
KGBIGCOUNTRY
MECH, VA
2004 RCSB/2005 QCSB
How are the Ctds primed stock? With an aftermarket lift pump that would do the priming to get the injectors and pump fed but how it it done stock on these trucks? Also would he have to crack the lines to burp out the air or is that not serious enough of an issue to be done? when I have done injectors on equipment I know I have had to crack the main line for the pump then the feed lines for the injectors also.
Mopar1973Man
New Meadows, Idaho
Typically you crack 1,3,4 to bleed the lines out. Tighten them down and fire it up.
dripley
hickory, nc
2002 2500 ho 6 speed 4X4
5.9 24v cummins
wel dave i forgot you had this page. i just changed my injectors out last weekend and you are chicken chit if you dont do it your self. it is quite easy. you dont need a spark plug wrench they just pop out. i was surprised at how easy it was. you get her opened up and do #! and just repeat. mike has a good point on the cleaning though. i sprayed my down pretty heavy before i took a bolt out of anything.
CumminsCrazed
North Central Iowa
5.9 Cummins 24v
obviously hes already done it as truck is sold but yeah, take VC off, take lines and X tubes out, use valve cover bolt to pop old injectors out, use same bolt to pop new in...i did all 6 of mine is about 45min to an hour. Hardest part was # 6 line, tube and injector popping back in.
ChloeBrooks
