need some help
CjR
5.9 24v
Hi there, I'm new to this so I've posted this in the wrong place please point me in the right direction. I have an 05' 3500 with a 5.9 24v, it has a AFE stage 2 cold air intake. has 180,000km on it, the problem I'm having is it starts really hard. I've put new batteries in it but now i'm starting to think that the lift pump is having issues. is there anything I can do to check this? or is it something a diesel shop needs to check? if it gets cold at all outside and I don't plug the truck in, it won't start.
Thanks for your help,
Colin
03MopaRamman
RAM SPORT / 18 SRT
Southern Alberta
Welcome to RF. we got some real knowledgeable Diesel Guys on here and sooner or later one of Umm will chime in and help Out.
Danny
Stangshcky12
Oshkosh, WI
5.9 Cummins
It probably wouldnt hurt to check the grid heater relay to make sure its still working
If not that I would start checking fuel pressures
03MopaRamman
RAM SPORT / 18 SRT
Southern Alberta
Good to Go then (Dumb Gasser Comment!).
C
CjR
5.9 24v
thank you
USMC1188
SW Ohio
None
Truckless...
While you are at it, check the cables all the way through the starting system to make sure everything is tight and in good shape
