Well it looks like everything was pretty much covered already. Great job cummins crew!
If you're not in an emissions state/county delete your truck! Not only will it be more efficient and powerful, but you'll double the life expectancy and stop your motor from destroying itself.
While your at it, remove the grid heater as well, as it's just a carbon/soot magnet and limits your intake flow significantly when it is covered with crap. Pull the fuel lines and rail off and you'll see what I'm talking about.
Here's a picture of the grid heater, non-deleted after 150K miles. Just think, somehow air gets passed there and into your motor... poor cummins!
I went with an H&S Minimaxx and love it! Little spendy, but worth the money. I didn't although, like the mickey-mouse install kit they supplied. The fuse extender seems like a fire waiting to happen.
So I mounted a blendmount to my mirror and wired mine up to the mirror itself. Now it starts when my truck starts up. No more double starts from the MM like when I had it wired to the fuse in the fuse box.
[yt]c9JuNRL-mf0[/yt]
If you can't find one from a dealer, there's still plenty of people selling them used on the forums. And like stated, you don't need to go with the Minimaxx, the XRT pro works just as well, just without the display, readings and guages.
Let me know if you have any questions. Here's some of the things I did to mine to increase longevity and efficiency :
http://www.ramforum.com/f17/trups_diesel_mod_thread-33633/index3.html
