69mach1
- Apr 11, 2016
- 169
- 28
- 2013
- Cummings 6.7
I have TXL wiring, fog light connectors, and PDC pins to make a complete 2013-2016 harness from the fogs back to the PDC (bypassing the i120). That's my plan. Just need to lay it out and build one to test/verify once I get some other harnesses finished.
Anyone know what the factory plug/bulb is at the back of the fog lights (2013+)?
I assume its a 9006 or something like that; it would be nice to id the yazaki or tyco PN from TechAuthority.
Mopar hasn't released a add-on Foglight kit yet like they did for 09-12 trucks and I'm not sure if they will have a separate section of the foglight jumper harness available anytime. So for now you have 3 choices.
1- buy the complete headlight wiring harness for around $150 (I think) which has the pig tail connection for the foglight jumper. I have no idea how hard swapping this one in would be, or just steal the wiring for the fogs from it and install them onto your truck.
2- find the female connector and the correct size pins for both ends(I think, don't remember which one it is) and build your own harness
Or what I did
3- cut the end off the jumper, tie the 2 grounds together and find a good grounding point. Then extend the 2 leads to the tipm (or whatever it's called now) and tap into the foglight feed wires in slots 23 and 24. They will be white/yellow and white/orange. Be careful because the headlight wires are the same color.
It may take the dealer a few tries to get the sales code to stay. It took 4 or 5 tries before mine took.
Everything will function as if it was installed as a factory option.
If anyone has any questions about any of the install feel free to ask. I'll post some pics of the wiring and diagrams later.
Here is a link to where you can access the wiring for 2010+ trucks
https://techauthorityonlinedemo.extra.chrysler.com/service/repair/wiring/view/classic.htm
Sent from my VS985 4G using Tapatalk
Try AllMoparParts.com or contact Benny via forum PM (preferred vendor).Where can I find this fog light kit for 2010 2500?
Slt's aren't pre-wired for fogsmy truck is 2013 SLT and has the black module , any info on the pins or the location of the fog connector if its already there
I'm in the same situation with my SLT. Planning on adding in factory wiring/making a custom harness from scratch. You can read back a few posts for the info you need (it's not a lot of posts really).my truck is 2013 SLT and has the black module , any info on the pins or the location of the fog connector if its already there
M² Mods - From my non Flammable S7!
There is nothing from the PDC on the tradesmans to connect foglights to. I believe mpgrimm is in the process of/or will be able to building the missing section of the harness. Only other options at this point is buy the complete headlight harness w/fog light wiring and either take the fog light section out and install it on your truck or replace the complete harness. Option 2 tap into the fog light feed going into the PDC (pins 23/24)and run wires to the jumper. You'll still need the switch w/fogs and sales code LNJ added.Does anyone think this plug and play if I have the factory harness from the i120 outward? I have the oem harness from a truck with fog lights. I can't tell if something needs to get hooked into the PDC. I have a 15 2500.
Yes
