tunlrat1
Ok guys this is my first attempt at a how to, so bare with me, I saw a few people asking how to replace their scratched lense on premium clusters so I figured I would show a quick how to.
First here is a pick of the tools I use, I've done a lot of iphone and tablet repairs so I've had these tools, but a pair of flat thin screw drivers will do just as well.
There are 10 clips around the cluster, the easiest way I found is to start by tabs that hold the cluster in the dash, place a flat tool between the white cluster and lens applying tension, this way when you start with the clips around the tab they stay open. slowly pry the clips open. do the 2 around the tab and then the one on the side. Then do the other side.
Then slowly turn over and do the four on the back start with the outside ones first and finish with the middle 2
If everything was done correctly the lens should come off.
If you need to get to the board for any reason there are 8 clips that you can pry with you finger they do not require a lot of force
To reassemble just do everything in reverse, I hope this helps someone out.
