wermbang
- Jun 29, 2010
- 9,724
- 214
- Iowa
- 2001 Off Road
- 5.9L V8 Sport
Brought to you by RamTech
Oil Change Indicator System
The oil change indicator system reminds you that it is time to take the vehicle in for scheduled maintenance.
On the Electronic Vehicle Information Center (EVIC) equipped vehicles “Oil Change Required” is displayed in the EVIC and a single chime sounds indicating that an oil change is necessary.
On non EVIC equipped vehicles “Change Oil” flashes in the instrument cluster odometer and a single chime sounds indicating that an oil change is necessary.
Based on engine operating conditions the oil change indicator message illuminates. This means that service is required for the vehicle. Have the vehicle serviced as soon as possible, within the next 805 km (500 miles).
NOTE:
Oil Change Indicator- Reset
The vehicle is equipped with an engine oil change indicator system. The “Oil Change Required” message flashes in the EVIC display for approximately ten seconds after a single chime has sounded, to indicate the next scheduled oil change interval. The engine oil change indicator system is duty cycle based, which means the engine oil change interval may fluctuate depending upon your personal driving style.
Unless reset, this message continues to display each time you turn the ignition switch to the ON/RUN position. To turn off the message temporarily, press and release the Menu button. To reset the oil change indicator system (after performing the scheduled maintenance) perform the following procedure:
NOTE:
- The oil change indicator message will not monitor the time since the last oil change. Change the vehicle oil if it has been six months since the last oil change even if the oil change indicator message is not illuminated.
- Change the engine oil more often if you drive the vehicle off-road for an extended period of time.
- Under no circumstances should oil change intervals exceed 10,000 km (6,000 miles) or six months, whichever comes first.
- Turn the ignition switch to the “ON” position. Do not start the engine.
- Fully press the accelerator pedal slowly three times within ten seconds.
- Turn the ignition switch to the “LOCK” position.
