DIY Bed Liner
Rusty1500
Michigan
Whats your Guys favorite Bed Liner kit. Some pictures would be nice. Im looking for a kit and i want to know the best for the cash...
02blkram47
Lebanon, NH
2018 Ram 1500 Limited
I used the herculiner stuff from autozone. Went on easy and seems really strong.
huntram03
Cincinnati Oh
6.7L CUMMINS
I used the Herculiner on the bottom and over the fenders.. haven done the bed yet cause I need to replace the tailgate.. The hardest part about mine was taping the curve to match the fenders.. the straight parts were easy.. Just follow the directions and double up arount the tape lines so you can pull the tape off while its still wet.. You dont want to try to pull tape off after it drys that requires a razor blade close to the paint and we all know how that could end up..
TexasRammer
College Station, TX
lots of people say good stuff about herculiner on here. thats what dave(ramhunter9) uses when he does all of them. im sure he'll tell you about it
ramhunter9
P-Star Jeep Wrangler
Hurc is all I use on all my trucks and customers trucks. It's all in the prep
nim81
Fredericktown, MO
5.7L
I use rustoleum spray on. Awesome stuff, but like Dave said, it's all in the prep
Sent from my iPad using Tapatalk HD
iSlacker816
Kansas City, MO
5.9 (360ci) Magnum
As this would be a good thread to ask on, can someone give some good pointers on prepping the area's getting herculined?
huntram03
Cincinnati Oh
6.7L CUMMINS
They give you a green scuff pad with the kit.. I threw it away and used 600 grit sand paper then used Xylene / Xylol to clean it both before and after sanding... The better you scuff it and clean it the better it sticks..
iSlacker816
Kansas City, MO
5.9 (360ci) Magnum
So 600 grit sand paper would work better than the scotchbright pad it comes with?
huntram03
Cincinnati Oh
6.7L CUMMINS
I think so! You really have to work that pad to get it scuffed up.. idk about you but if I can do less work with the same or better results thats how im gonna do it lol..
iSlacker816
Kansas City, MO
5.9 (360ci) Magnum
Lol if it works better and still lets it adhear well than sounds good to me. The 600 grit doesn't dig in too deep to the paint does it?
huntram03
Cincinnati Oh
6.7L CUMMINS
No not at all.. I dont think I even got down to the paint, it was just scuffing up the clearcoat.. You dont have to put much pressure on it at all to get twice the scuff as you would with the green pad.. Thats what I did and it worked great for me.. Unless Dave / Ramhunter9 has a different idea or way to do it that could be a little easier..
ChloeBrooks
