Go Back   DODGE RAM FORUM - Dodge Truck Forums > Dodge Ram Generations Forum > 2nd Gen : 1994 - 2002 > Tech Info > 2nd Gen DIY
Sponsored Ads
Register to remove these ads.
2nd Gen DIY
Installing cab lights in 2G Dodge Ram 2500
This is a discussion on Installing cab lights in 2G Dodge Ram 2500 within the 2nd Gen DIY forums, part of the Tech Info category!
Register to remove these ads. It's free! Here's my write-up on Home Page of Mopar1973Man forum... At any rate, I ...
Reply
Old 12-02-2011, 08:47 AM   #1 (permalink)
Rogan68's Avatar
Ram Year: 2001
Engine: 5.9L CTD 24v 6 hole Bolt-action
Default Installing cab lights in 2G Dodge Ram 2500
At any rate, I installed clear lens/amber LED cab lights this past weekend. My truck did not have them from the factory, so I bought some EuroLite 9-LED ones for a Ford, from eBay for $70 delivered. I liked the Ford-style ones better, so that's what I went with. They arrived in a box, no instructions, no packaging, only an invoice, lights, and packing peanuts...
this style:
Since my truck didn't have cab lights, I had to drill..
In a nutshell:
  1. Drop headliner (phillips screws hold visors, pinch clips for overhead console, T20 for pass. side grab-handle, T20 for QC latch trim covers, snaps for a-pillar trim
  2. Tape a straight line from top corners of windshield.
  3. Measured 6" up on each side, and taped another straight line across.
  4. Found Center line, marked it on the tape
  5. From center line, outward, measure 8.5", mark it
  6. From the center line, outward, measure 21". mark it
  7. Once you have these lines marked, measure 5.75" from top edge of windshield, back. This mark will be the forward-most point of the cab light. (this will put the wiring of the Ford-style lights right about over the inner cab-wall hole.
  8. Using the base of one light, make a cardboard template of the light base, and drill holes where wiring and screw holes will be.
  9. Mark center line on template. This will aid you in lining/centering/straightening up the lights and marking the drill locations.
  10. Align center line of template onto each parallel line for the light locations, taking into account the front of the light base on the 5.75" back-set mark.
  11. Drill the three holes required by the lights (2 mounting screws, one wiring hole)
  12. I used an 1/8" (.125) bit for making the #8 screw pilot holes. Also a pilot hole for the wiring, to be drilled out to 3/8", or .375
  13. Apply a dab of clear silicon on each mounting screw hole on the cab, and a blob around the wiring at the light base
  14. Place the light base onto the cab, carefully ensuring that it's aligned properly.
  15. Mount the light bases using (purchased separately) #8 x .75 SS sheet metal screws, and snug them down evenly
  16. Once all are mounted, move inside the truck and wire lights in series.
  17. I grounded them within headliner, and ran 'hot wire' down driver's a-pillar, to headlight switch (remove bezel, 3 phillips screws and slide headlight switch out. Wire is black/yellow.
  18. Check for proper operation.
  19. Reinstall everything if all is good to go!
The measurements I used/came up with are on my 2001, so yeah, late 2G trucks. If you're using Dodge-style lights, then your front-to-back measurements may be different. I used the Ford style, so they're a little shorter, IIRC. My lights are 4" long, and the mounting screws are left to right. I think the Dodge mounting screws are front to back?
Regardless, from centerline of the cab, you'll find (when you drop the headliner) that the lights are CENTER, 8.5", and 21" from center, either direction. (or center 0", left-inner @ 8.5", left-outer @ 12.5" from left-inner, same for right side.
I think the wiring hole on inside of roofline (factory location) is about 7-3/4" from windshield edge.
Drilling that first hole was nerve-racking! Once I popped it through, though, it was all cake from there..
You don't really even have to 'remove' the headliner, just drop the front.
  1. 3 phillips screws on each visor
  2. 1 phillips screw on each visor retainer
  3. OHC has 2 pinch clamps and pull backward
  4. 2 T20 bolts retain pass. side grab handle
  5. both a-pillar trims pop off
  6. pull down door seals enough to clear the edges of the HL
  7. *if you have a QC, then torx20 takes the screws out of the overhead QC door latch trim covers
  8. Pop the two center plastic retainer pins in the rear/center headliner (leave the rear-most push pins in the headliner)
Then I just let the HL hang down in the front, resting on the front seat headrests.. This provided plenty of room to get in there and wire it all up.
Grounded the cab lights to a single point in the ceiling, and ran a single power wire down the A-pillar, into the dash to the light switch, tagged the black w/yellow striped wire (PRK LIGHT wire) and reassembled it all back.
Takes like 5 minutes to drop the headliner. you can leave the middle dome light alone; it's fastened to the headliner, itself, not the roof.
Overhead console. Open the garage door opener compartment. Two pinch clips in there. Pinch them and slide the console backward. Its a PITA but will come out.
__________________
'01 QCSB 5.9L Cummins - 6speed, Edge Juice w/Attitude, BHAF, 5" Diamond Eye TBE
'96 SCLB 5.9L Cummins - #10, BHAF, 4" DP, 7" Miter Stack, Leveler, 4500, M275s, Jake
'03 QCSB 4.7 2WD - all original, 98k mi., dual exhaust - My late father's truck. RIP, pops! 4/11/36 - 3/26/11
Rogan68 is online now   Reply With Quote
Old 12-02-2011, 09:18 AM   #2 (permalink)
wermbang's Avatar
Site Administrator
Ram Year: 2001 Off Road
Engine: 5.9L V8 Sport
Default
Thanks for the write up!
__________________
RamForum.com Administrator
Superchips 3715;3rd gen 20s; Cat back exhaust, no muffler;Custom Grill Insert; SRT Hood; Hummer Nerf Bars (PD);Roll Bar (PD); Halo Projectors w/ 6K HIDs; Tow Mirrors; Body matched antennae base and handles; Custom tail Stripe; Custom decals; Painted frame, suspension parts, and wheel wells; Air Horn; Aluminum fuel door; one of kind dents and scratches; 2.5" TGC Leveling Kit; Bilstein 5100 Shocks; LED dash lights ;Cleared needles; blue switches; Painted dash pieces; Pioneer CD player; Cerwin Vega 6x9s , Alpine 5 1/4;Kenwood amp; Boss sub w/Boss Amp; 5% window tint on the back, and strip on the front;[/COLOR]
New Here? Introduce yourself here - Click here to become a Supporting Member - Check out our Preferred Vendors!
wermbang is offline   Reply With Quote
Old 12-02-2011, 09:34 AM   #3 (permalink)
Rogan68's Avatar
Ram Year: 2001
Default
Sure thing!
__________________
Old 12-02-2011, 09:56 AM   #4 (permalink)
rambob's Avatar
Ram Year: 2001
Engine: 318 5.2l
Default
great info. just what I was looking for.
thanks
__________________
2001 RAM, 5.2l, 5" LIFT, 33" BFGs, 100 wt yellow fogs, all base model
rambob is offline   Reply With Quote
Old 12-02-2011, 05:50 PM   #5 (permalink)
ramhunter9's Avatar
Administrator / Owner
Ram Year: 1994
Engine: 7.5L
Default
Just ordered some cab lights .. this inspired me thank you
__________________
RamForum.com Administrator/Owner/Vendor
Click the link for info
DB Truck Customs Facebook Page (Click Here)
dbtruckcustoms@gmail.com FOR ALL YOUR PARTS NEEDS or installs email/PM me for a price quote. If you want it chances are I can get it at a very good price ! Web Sight Coming Soon !!
ramhunter9 is online now   Reply With Quote
Old 12-02-2011, 05:53 PM   #6 (permalink)
Stangshcky12's Avatar
Ram Year: 2005
Engine: 5.9 Cummins
Default
Smoked would look awesome on your truck!
__________________
2005 Ram 2500 5.9 Cummins 6 speed
More Here
I blame spelling mistakes on my phone and I'm sticking to it!
Stangshcky12 is offline   Reply With Quote
Old 12-02-2011, 05:54 PM   #7 (permalink)
ramhunter9's Avatar
Ram Year: 1994
Engine: 7.5L
Default
Thats what I ordered ..LOL
__________________
Old 12-02-2011, 06:01 PM   #8 (permalink)
Rogan68's Avatar
Ram Year: 2001
Default
Hell yeah! Which did you order?
Sent from my rooted EVO's tiny keyboard with my opposable thumbs...
__________________
Old 12-02-2011, 06:04 PM   #9 (permalink)
ramhunter9's Avatar
Ram Year: 1994
Engine: 7.5L
Default
Recon smoked , JJ found them on Amazon for 75 bucks with harness
__________________
Old 12-02-2011, 06:40 PM   #10 (permalink)
rambob's Avatar
Ram Year: 2001
Engine: 318 5.2l
Default
I hate you Dave. And your well paying job and bonuses, and extended free time.
By hate I of course mean envy.
__________________
Reply
Bookmarks
Tags
cab lights on 2nd gen, cab lights on ram, diy cab lights 2nd gen, installing cab lights
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Installing behind the grille lights wermbang 2nd Gen DIY 2 11-03-2011 08:13 PM
Installing behind the grille lights wermbang 3rd Gen DIY 5 10-28-2011 01:30 PM
2001 dodge 2500 5.9 25V Grayson0017 Garage 5 06-18-2011 07:15 PM
Help me ID transmission 04 Dodge Ram 2500 olddodge Engine & Performance 4 05-25-2011 04:52 AM
Fully Driven Auto Network
GM Truck Forum
Ford Raptor Forum
Chevy Tahoe Forum
Chevy Cobalt Forum
Chevy Camaro Forum
Toyota FJ Cruiser Forum
Ford Truck Forum
88-98 GM Truck Forum
73-87 Gm Truck Forum
Ford Expedition Forum
Chevy Equinox Forum
Chevy Cruze Forum
Jeep Liberty Forum
Jeep Forum
Dodge Ram SRT10 Forum
Chrysler 200 Forum
Scion xD Forum
Scion xB Forum
Dodge Challenger Forum
SRT Forum
Nissan Titan Forum
Buick Enclave Forum
Cadillac Forum
Cadillac XTS Forum
