iakshawks
Long time reader and follower, first time poster. I have not found any discussions about the issue that I am having, so I guess I have to ask the question.
I installed the LMC heavy duty headlight harness well over a year ago and it worked great. Before I installed the kit, my lights started to flicker one day. I didn't see any signs of melting at the pigtail or switch (and it looked like a previous owner had replaced it before), so I bought the kit instead. No problems at all until last week when it went out. High beams work, parking lights, dash lights, a LED rope light installed below the headlights and tied into the headlights all worked. I found it very odd that the rope lights worked but no headlights since they are tied into the headlight wiring and not the parking lights.
I hear a click in the relays like I should, and switched the relays to see if the low beam relay went bad, but still no change (high beams still worked, low didn't). I had some corrosion at the battery terminal where the harness tied in. Cleaned it, and part of the harness as well, still nothing. I removed the harness and went back to the original set up, and everything works again. I am leery of leaving it in its original set up since it had problems before, but cannot think of what could be wrong with the harness.
I think I have ruled out the relays, I don't see any breaks in the wiring, only place with any wear and tear is the wire going to the battery. Is there a fuse or something in the harness? Seems like there might be in the wire going to the battery. Any one else have any issues with the LMC harness? It was highly recommended on the forum when I originally bought it. Should I just replace the switch and use the original set up?
Any help is appreciated. BTW, I can usually problem solve most situations with my truck, but I am no mechanic or electrical expert at all.
