Need urgent help for a friend on his Fabtech 6" kit
adamwilkes14
My buddy has a 2002 Ram 1500 2WD with a Fabtech 6" suspension kit on it. Yesterday he heard a pop and found this.....
I am 99.9% sure this is a bracket included in the kit to raise the stock front sway bar up off of the lower control arm where it is mounted from the factory (I am going off some pictures, but I am fairly certain of it)...can these brackets be purchased through you or only through Fabtech directly?
Any help in helping me help my friend would be greatly appreciated...
KGBIGCOUNTRY
MECH, VA
2004 RCSB/2005 QCSB
Wow what was he doing to put that much strain on that?
KGBIGCOUNTRY
MECH, VA
2004 RCSB/2005 QCSB
I was thinking four wheeling hitting a hard or deep rut at speed with some hoonkin tires. Looks like pressure came at it a few diff ways.
CTD
I can't see the picture but Fabtech will cover under their warranty almost any broken component from their kit. Have your buddy give Armen a call: (909) 597-7800 --- Dial that number and ask the receptionist to be transferred to Armen or someone in the warranty department.
We do not stock individual components like that. We can special order them from Fabtech but in most cases going direct to Fabtech is a better idea. He will need some sort of proof that he is the original owner of the kit. If it's a 2nd (or 3rd) hand kit Fabtech may or may not cover the replacement under warranty.
-Jeff
A
adamwilkes14
From what I understand it just popped while driving home
Four wheeling while towing a heavy load?
the previous owner trashed the truck pretty well, but no, no towing
-Jeff
Thanks Jeff, unfortunately he is not the original owner of the truck or the lift. We were lucky enough to find 2 retailers that stock the sway bar brackets last night after I posted this thread...part #'s FF44005 and FF44006
ramhunter9
P-Star Jeep Wrangler
Case closed then I hope Ramstrat gets her going !! Good that you found some local .
Bad Habit
Land O Lakes
Modded 4.7l
i was with him, nothing out of the normal driving we were actually stopping at lowes and it popped entering the parkin lot...
ramhunter9
Stress from the heavy ass tires ??
Bad Habit
Land O Lakes
Modded 4.7l
in all honesty i dont think so, i think it was just an under lying pc that had been cracked for a while, possibly from a previous owner, he dont beat on it at all, and the tires really dont weigh any more than my buddies does with his 4wd on 38s, and lift....
A
adamwilkes14
Just looking at them they appear to be not as strong as you would think they should be, but I could be wrong. You would think they would gusset them where the sway bar attaches to the bracket.
ChloeBrooks
