Added USB Charging ports to rear doors
NL74
SitKneelBend
St. Louis
3.6 Pentastar
Pretty cool...
misfit77
I saw a write up on here before.
I wonder if hes selling them ir some one took his idea and went with it
Dammit i dint facebook.
Rlaf75
East Hartford CT
I like the idea but my 21 BTS already has like 6 USB ports in the center console plus a couple aux ports and a conventional outlet for a laptop
gambeno82
McDonough, GA
Not a bad idea.. but just thinking about the cord in the way!!!, hey if you like it we love it!!!
bruce219
ca
pentastar
I also added them to my rear doors,its easy to do.
maxiderm
Bakersfield, CA
Pentastar 3.6
Would this work to add one single USB charge port to the front passenger side door? Or does this person only sell them in packages of two? I lost my center console charging ports power due to installing an aftermarket stereo, so I only have one charging port for driver and passenger to share (the one under the AC controls). Adding one on the front passenger door would be really helpful.
TRRUCK
Mississauga, ON, Canada
Cummins 6.7
I did this on mine without the kit. Easy if you're ok with wire splicing.
I got some usb ports off of Amazon, and spliced and soldered the connections to the wires which were easily accessible.
DoughRat19
Massachusetts
2019 Classic
The harnesses are for the rear doors only. Front doors use a different connector.
QwikKota
5.7L
That's why he posted in the 4th Gen area. :gr_grin:
Athlium
Tacoma, WA
3.0L EcoDiesel
