Hey everyone first timer here not too sure how to navigate this site that well.
My question: My 1996 ram 2500 Cummins doesn’t communicate with scan tools to diagnose anything. I even took it to a mechanic. I’d assume right off the bat that it’s my PCM or a wiring issue.
I just installed a...
I've researched this a little online, and seen similar issues on other Dodge Rams and other brand (i.e. Ford) trucks: my Odometer light on my instrument cluster fades in/out, and has been getting progressively worse. Its to the point where the Odometer light on my cluster is out for a week or...
Help! My brake light and EPS lights both came on after I had my rear brakes changed. I just thought maybe a sense was knocked loose but now it seems like my brakes arent working.
I have a 2008 Ram 1500 5.7 Big Horn edition. My TPM, check engine, abs, parking brake, check gauges, and tire pressure warning lights all come on at the same time and the speedometer and the tack drop down to zero. Square boxes also appear around all of the gear indicators above the mileage...
I have a 2015 ram 1500 sport. I was driving the other morning, it was pretty foggy so I had my fogs on and the cluster lights turned down. I looked down at my speed and noticed my tacometer and speedometer lights were flickering. Anybody ever experience this? Also on a side note my uconnect has...
On start up the dash lights flicker and it sounds like the starter is engaging. You hear 3 kicks at the beginning when all of the lights start to flicker and then it finally turns over.
***please reference the below video to view the issue***
I’m not sure if this has anything to do with it or...
