I have got this code awhile back, and took it to a diesel mechanic. They said it was the fuel filter, so that was replaced. Went another 5k miles and it popped again...
Any know much about this?
I heard back gas can throw the sensor? Is it an easy fix? Expensive?
Thanks.
I need some advice about the fuel rail on my 99 5.9 Ram 4x4. The connecting hose between the rails burst. Is it ok to replace the hose or do I have to replace the complete rail?
I have read that its ok to replace as long as you use a high pressure hose with clamps
and I have also read that the...
My 2012 5500 has just started throwing the same codes P0087 my mini max says it’s fuel rail/system pressure too low, and it’s throwing P020B fuel injector 2 performance and throws that code for injectors 2,3,4,5, what would cause it all the codes to come up all at once. If some one could help...
