When I start my truck up, I usually let it run for a minute before I take off, when I drop it in D and go it sounds like I can hear the fan or something like it kick on for about 10-20 seconds while accelerating and then it quiets back down. It usually only does it when I first start it up and...
Last year, my truck got syphoned for gas and ever since it doesn't start up when i turn the key. it takes usually 2-3 times to startup. Any idea on what the problem is or how to fix it?
I have a 2022 Ram 2500 Tradesman, bought with 4,000 miles on it in February (valentines day - yes, caught crap for that) got a pretty good deal I felt, dealership re upped the 3yr/36k bumper to bumper since it was so new. Had the truck for 2 weeks and noticed a knock at startup after sitting...
As the title says, all the accessories in the truck work, the power is definitely there. When I turn the key the I can hear a click like it is trying to start but no actual turning over. It seems to be some weird connection from the starter, to a little box that is connected to a ground. Has...
Hope y’all are doing well. I have a 2012 Ram 1500 and I’m having some starting issues. The issue I’m having is the truck will click but will no start until I’ve moved it from park to neutral and then back into to park. From there it starts right up. I’ve had a dealership look at it and they...
So the truck sits for a around a week most of the time or even up to 15 days sometimes before being started. Over 6k miles.
I run Redline 5W20 (going on a full year). Based off how often I drive I'll be conducting yearly oil changes with 5W-20 (not the 5W-30 because that may be too thick for...
I am new to owing a Ram so I am not familiar with what is normal for these trucks. When I first start up after letting the truck sit overnight the idle surges/searches for a few seconds before it smooths out. It runs fine afterwards and doesn't have the wondering idle again until the next...
