throttle body
  1. P
    2019 Cummins 2500 Electrical Issues- Huge Mystery
    Hello, 2019 Ram Cummins 2500 4x4 Bighorn- 119K Miles, very well maintained, no wrecks, fires or hard use Issues- Passenger Headlight not working (bulb replaced, all other lights work) No code Voltage jumps (new batteries this year, connectors are clean, wires appear to be solid) No Code...
  2. M
    Throttle Control, 4WD, Coolant
    Stumped on this one. When I first start my truck every day (when it is still cold outside), within 2 minutes I will get: -Throttle Control light (lightning bolt), -Serv 4WD light -temp gauge stays all the way cold -coolant temp reads as <100 All of these stay that way for the entire drive...
  3. M
    Throttle Control + 4WD Light + Coolant Low
  4. D
    1988 5.2 Throttle body replacement
    I just picked up my grandfathers 88 d250 5.2l it was running good a couple years ago but noe has a completely frozen throttle body, valves in the throttle body are stuck and no amount of wd, liquid wrench, pb blast or anything will free it up. Went to take out the valves and the heads of the...
  5. D
    Etc light
    Hi all. My etc light keeps flashing. I replaced the throttle body and the map sensor as i was getting codes showing the Barometric pressure was off. Truck ran fine for 30 min then i lost power and etc light started flashing. Now im getting a code for sudden low air flow. It will idle and drive...
  6. ericthelion
    Throttle Body Upgrade and Transmission Upgrade
    I am currently looking for a 847, 86mm fastman throttle body however he has his site closed wondering if anyone has any spare to sell? also was looking for any advice on transmission upgrade for a 2wd crew cab 09 5.7 Ram with 3.92 gear ratio. im planning on installing a cam and long tube headers...
  7. duckman631
    Throttle body cleaning and catch can
    2016 5.7. 88,000 mi. Received a billet catch can for Christmas. Between this and that and the weather, I finally got a free day with relatively decent temps and no rain. Wanted to do the throttle body cleaning before installing the catch can. I watched a you tube vid and I must say, taking off...
  8. KevinWilsonSBC
    Diablo Sport I3 Datalog TPS not 100%
    First of all I am new to this Forum so thanks for such a great forum! I have a 2013 RAM 1500 Hemi 5.7 with K&N CAI, Flowmaster FlowFX direct fit, and Diablo Sport I3 with Diablo Tune "canned" tune. I have done some data logging with the I3 and I see when I do WOT logging the TPS Absolute %...
  9. SCr1pT
    4th GEN RAM Parts List , CAI, CatchCan, Cover, Fogs
    OR BEST OFFER Selling my 2016 RAM 1500 Laramie and Buying a SRT Durango. Have lots of different parts looking to sell. Located in Boonsboro, Maryland 21713. Willing to drive for extra cost. Buyer pays shipping. RAM 1500 Grill : Asking $100 1. Chrome Grill. SOLD. SOLD. SOLD 2. Max Steel...
  10. H
    throttle body 2004-2005
    I have an 04 Ram with 5.7. I just purchased a new throttle body but it is for an 05. From what I have read the only difference is a slight change in the plug, all wiring is the same. I can verify that the 05 will not plug into my 04 harness. Are there any adapter plugs or any modification I can...
  11. njohnson6425
    Throttle Body upgrade
    I was wondering about the advantages of upgrading the throttle body. I have a 2008 Ram 1500 with the Hemi 5.7. I'm not sure if my stock size is 80. I was thinking the 84mm size. Any thoughts?
  12. D
    Throttle body spacer worth it?
    I have a 07 5.7 ram was looking for cheap upgrades to make and came across a throttle body spacer, saying they can give alittle hp and torque and improve MPG. Are they worth it?
  13. THRobinson
    Stalls and Running 'Oddly'
    Had this Ram about half a year now... and for the most part it's been fine, but lately been having a few quirks. Posted before about an issue... auto shift on the steering, sometimes won't pop into Park without a few attempts, and a few times flipped into 2nd while driving because between D and...
  14. B
    Air box to throttle body boot on magnum 4.7
    I am a new owner of this truck and was having some issues with the truck stalling immediatly after start up it would run for a few seconds and fall on its face. I got it taken care of and realized some of the neglect the previous owner has shown this truck. First of all as I removed the air...
  15. Christian1500
    Swoosh or Air noise question (CAI)
    So I been hearing this swoosh or air noise coming from the cold air intake area (Spectre cai :argue:), and its mostly happening when I'm speeding up in the highway and then letting off the gas pedal; it sounds like the air is coming back from the aluminum tube and to the air filter and out...
  16. S
    Engine up grades
    Okay I’m thinking of doing some upgrades to my engine starting with a throttle body spacer and ram air intake. I was also thinking of switching out the coil packs and sparks plugs for higher rated coil packs and spark plugs with a wider gap. Would those be worth it? Plus injectors, what are the...
  17. Willems334
    Throttle body to fuel injection swap.
    Look to remove my throttle body and swap to EFI. has anyone done this on a 1999 5.2 318 ram 1500? Any kit i can buy or tips for doing so? thanks in advance.
  18. Steve Marin
    Bored Out TB in High Altitude
    Hey all, I'm considering adding a bored out TB to my 2017 1500. I live in Jerome Idaho which has an elevation of just over 3,700'. I was chatting with a local engine guy and he mentioned that one of his buddy's had three different TB on his car up here and the stock did the best, yet others...
