tire size
  1. A
    Need Your Help!! 20x8 stock rim: 295/65r20... Too Wide???
    I've been tirelessly researching what size tire to go with on my 2016 1500 Big Horn. 3" lift, stock 20x8 rims. I was really wanting to go with the 295/65r20 (35.1" x 11.6") but was told tires will cup as they're too wide for the rim. Wife won't let me buy new wheels, so I'm stuck with fitting...
  2. jacoblane216
    Tire advise needed please help!!
    I’m getting ready to order wheels and tires for my rumble bee, I’m gonna get either the 22x10 hellcat replicas or the 22x10 srt-10 replicas, I have 2” drop shackles in the rear and plan on new bilstein shocks in all four corners. I wanted to know what tire sizes to get for my wheels and not have...
  3. R
    Gas Mileage and performance with stock gearing and 33s
    Hey all, first post to this forum, and I'm sure I'm asking a question that's been beaten to death already, but couldn't find anything in the thread search. I have a 2012 2500 4x4 double cab with the 5.7 Hemi, stock gearing, stock ride height, and slightly above stock tire size (31s). I'm...
  4. S
    Stock fitment 22x12 -51MM
    Can my 2021 5th gen on stock ride height pull off a set of 22x12 -51MM on 325/50 tires? Tire- 325/50R22E (35"X12.75") FUEL GRIPPER AT ALL TERRAIN TIRES Thanks
  5. T
    Will 305/70/18 fit on my 2019 Warlock?
    I need to buy new tires and wheels and I’m wondering if 305/70/R18’s will fit without rubbing or anything on my 2019 Warlock. It’s completely stock right now. Thanks!
  6. J
    Maximum Tire Size for stock 2020 Ram 1500 Bighorn 4wd Crew Cab
    Hi all. I'm a new member and I have a question. I just bought a 2020 Ram 1500 Bighorn 4wd Crew Cab. It came with 275/55R20 tires on 20"x9" chrome wheels. I'd like to put 275/60R20 on the same rims. Has anyone done this and verified that there is NO rubbing or any other issues? The tires I want...
  7. Doug Ram
    Tire and Wheel Size and Preference
    OK folks, I know this has probably been asked a million times, but pardon my stupidity. I have on order a truck that is going to be delivered around February 12. Its a a Ram Big Horn 1500 short cab EcoDiesel that's going to spend its life pulling docks out of the water and yanking a 22 foot...
  8. L
    What size tire??
    I have a 2017 Ram 1500 I’m looking to get some all terrain tires put on. I recently installed a 2.5 inch spacer in the front to level it out. I’m looking at getting some Nitto Ridge Grapplers and I’m torn between 285/65/20 and 285/60/20. I want to go as big as I can without any rub but I don’t...
  9. N
    Thick Tire on Narrow rim
    So my friend just told me that I can fit a 33"x12.5" wheel on my 20" Stock Rims. Is that possible? Or does he not know what he is talking about. Basically are there wider tires that work on narrower rims? Does that even work?
  10. kurek
    Jscan - better than AlfaOBD?
    I had never heard of Jscan before but I bought a Jeep recently (still have the Ram, both 2015 models) and needed to adjust tire size. I was introduced to Jscan which works awesome on the Jeep - it looks like it has most of the stuff that AlfaOBD has but in an easier format. And it looks like...
  11. Drunken Hamster
    What are the top choices for a 31"-32" tall 265-305 width performance tire on a 20" wheel?
    Looking for a good set of tires to put on my truck when they need replaced[which is soon]. Truck's gonna be at stock height, but since I can't find any of the typical sport tires in the stock 275/60r20 size, and since it'll be shackled with the O/L out, and since I've seen a 265/50r20 look GOOD...
thoffmann517
