04 1500 5.7 Ground strap location/Issues where do they go?
Joe.G
2004 SLT Quad Cab Short Bed
Hi, I noticed that on my 02 1500 5.7 on the passenger side near the Cat/Manifold I have a broken ground strap that is bolted to a heat shield near the floor and it is broke, I can not see where it went to any ideas on this one?
I also have a ground strap that is bolted to each valve cover roughly in the middle, the strap is about 4 inched long and the it is just resting on the top of the stud that it is bolted to, where are these supposed to go? thanks
Fast69Mopar
I don't know if you ever figured out the location of where this ground strap is attached since you posted your question 6 days ago but, if you have the ground straps that attach to the rocker covers then what I usually do with this particular ground is secure it to one of the screws that holds the PCM in place. Several Mopar vehicles over the years have had ground straps that are secured to the PCM case. Just make sure you have it attached to something to where it can provide a good, quality ground.
