Nick Grubb
- Sep 27, 2021
- 1
- 0
- Location
- Otwell Indiana 47564
- 2007
- 5.9 diesel
06 ram 2500 5.9 48re 4x4
wont crank, replaced park neutral switch,still no start. cleaned battery posts and cable ends. when key is in run poss.the gear selector in dash wont show veh in P or N when shifted in those gears. if you turn key from off posisition to the first detemt where only mileage and shiftselection is light up it will show every gear you put shifter in,PRND2L. Turn key to run and both P and N circle around it goes out. i changed neutral switch with 3 different one with same outcome. could i have a PCM problen or something im overlooking? HELP
