Here's what I've done so far:
I've got a 2006 ram1500 - 4.7L v8.
Last fall, my a/c started not working all the time.
Not sure what was happening, but it was intermittent.
I smelled electrical smoke at one point and then it never worked again.
I finally got around to trying to fix it.
It was not locked up so I checked the compressor clutch. It was pretty worn so I replaced it.
New clutch is in.
It cycles on and off when the ac switch is turned on. So it appears to be engaging and disengaging correctly.
The R134a was a little low so I added some to the low pressure port. It looks like the pressure is at about 50 psi.
I checked the condenser fan and it is working also.
Does anyone know which direction I can look in to verify what may be the problem?
Thank in advance-
-Cash Case
