Jimmy68
- Aug 30, 2015
- 1,419
- 645
- Location
- Lethbridge Alberta Canada
- 2001
- 5.2L Magnum
I have LEDs and no completely hazed housings. I can see just fine.
I said stock. You ****** berry.
I've got some pretty bad housings on my truck, it was impossible to see before switching to LEDs, i'm almost afraid to put in new housings for fear of blinding myself with the light reflected from the signs
But really, LEDs are bright as day.
Well I have power right up to the wiper motor so I would say thats my problem. Gave it a littl tap and it actaully went through a wipe cycle once before seizing again. Will install a new one if I can figure out how to get the damn wiper arms off hahaha.
Still stuck on the fog lights, will have to trace out the wire on the next nice day.
Have a grinding and clicking noise coming from the drive belt/pulley aseembly now though. Wondering if its the idler pulley or possibly ac compressor. I have video id lie you guys to take a listen to, just wondering if I should post on this thread or under another? Thanks!
Haven't had much time to troubleshoot the fog lights, did however remove the fog light relay and replace it with another, lights remained on though... Even with no relay in they stayed on so must be shorted somewhere before that...
The belt /pulley noise is getting worse.....took a video today, if you get a chance please check it out, any feedback would be greatly appreciated!
https://m.youtube.com/watch?v=S9gmsCtfuNY&feature=youtu.be
The more I hear it the more I'm thinking water pump as well...the clicking is fairly intermittent. Not sure if be comfortable swapping that out myself.....am I looking at a fairly expensive fix?
Thanks for the schematic info! I'll check it out tomorrow.
The daytime running lights could very well be a part of the issue!The truck originally did not have automatic daytime running lights but when I took in for an inspection the mechanic who looked it over added a "daytime running light kit" . Maybe not so coincidental .......
