XXSNOTRODXX
Hey guys, I know this is a ram forum. But I have already searched the web and posted on Jeep forums looking for answers and have yet to get any replies so I figured Id give the Mopar heads here on the ram forum a chance to help me out here.
Ok, so its my wife's 05 grand cherokee limited. 80k miles. 5.7.
First I will start with a little run down of the history and then move onto the issues...etc...etc...
Last summer I put a crankshaft position sensor, camshaft position sensor,egr valve and a few other things on the jeep as preventive maintenance as I had heard they were common problems on these jeeps and I wanted to get ahead of the curve.
A couple months ago I had to re-replace the egr valve as it had already failed (whatever advance auto parts carried... I believe car quest brand).
Ok on to the problem. Went to start the jeep yesterday and it took about 10 seconds of cranking before it fired up. She drove a few minutes and noticed the check engine light was on. She drove it home about 15 minutes and parked it. It was still running fine without issues aside from the check engine light being on. No knocking or anything either.
Did the key on/off trick and pulled up the trouble code message display and got 4 codes out of it.
The codes are as follows
code p0340 Camshaft Position Sensor Circuit Bank 1 Sensor 1 No Cam Signal At PCM
code p0016 Crankshaft Position - Camshaft Position - Correlation Bank 1 - Sensor A.
code p0325 Knock Sensor 1 Circuit (Bank 1 or Single Sensor)
Knock sensor (# 1) signal above or below minimum acceptable threshold voltage at particular engine speeds.
code P0330 Knock Sensor 2 Circuit (Bank 2)
Circuit Knock sensor (# 2) signal above or below minimum acceptable threshold voltage at particular engine speeds.
Today I took it for a test drive , again it took 10 seconds of cranking before it started (no hesitation to start when it finally starts) and it seemed to run fine. Maybe a slight hesitation under acceleration but not bad. I got on it a few times testing it out and it kicked down and sped up as usual under hard acceleration. Then about 5 minutes later it would no longer "kick down" under full throttle. And even from a stop if you floored it it would take off sluggishly and shifted weird.
Like it went into some sort of "limp mode". I brought it back home and parked it and checked codes again and there were no new codes. Still the same 4 codes.
Throughout all of this nothing sounded off. It still purred like a kitten, all gauges were within normal range. Idled smoothly.
Does anyone have any idea what would trigger these 4 codes to kick at once and toss a check engine light?.
Only thing I can think of is either the crankshaft sensor or camshaft sensor I installed last summer is faulty and causing issue (judging by the track record of the egr valves advance auto parts sells I wouldn't rule it out).. The only thing that makes me second guess that is that there are 4 trouble codes. So is it possible that 1 of the sensors is at fault and could trigger a chain reaction of fault codes in sensors that are not faulty?. Are the sensors tied together in such a way that when one has a fault that it triggers the others to act up or throw a code as well.
I can verify that as of a few weeks ago there was 0 codes stored in the computer as I showed my wife how she can check her own trouble codes without using a scan tool. I find it odd that all 4 codes popped up at once and now having these issues. I suppose a wiring issue COULD be the cause but I am doubting that to be the cause. My gut tells me cam sensor but I am confused on if that is in fact what could be causing this without knowing if one sensor can have a chain reaction and throw codes for other sensors when a fault is detected.
I apologize for such a long message, I just wanted to be as detailed as possible to have a better chance at a accurate knowledgeable response. And I also apologize for posting about a Jeep in the ram forum but I am kind of at a last ditch effort before I actually start getting dirty and looking under the hood for the cause of the issue.
If any of you could shed some light on the subject I would really appreciate it. Thank you in advance!.
