Need help with Front axle verification / install
Android051
Raleigh nc
5.2 gas
Hello, I am so confused right now as I have just now removed my front Hub and Axle assembly, but the teeth are different (see picture - bottom is stock, top is what I received with a "guaranteed direct fit") Is this normal? Should the teeth be this different for an aftermarket part? Or did they in fact sell me the wrong part?
1997 dodge ram 1500 sport 5.2 (ABS)
69_XS29L
Rockies
'95 2500 4x4 '03 OffRoad 1500 '85 W350 4spd
8L V-10, 5.7L Hemi, 360 4bbl
The top splines are typical for a Dodge Gen II Dana 44 left inner axle. The other you are showing is the stock Dana 44 axle end at the center axle disconnect, the right side.
If they both have yokes on the other end.
