Rough transmission shifts
Alberta
I had a seal changed in my transmission on my 2011 1500 while still on warranty. Now the warranty is up and my transmission is shifting hard.. I was woundering if they programmed it weird or forgot to clear codes maybe.. Plz help
RamCares
n/a
n/a
When is the hard shift occurring? – Kevin T, Social Connect Team
A
Alberta
Gearing up and hard down shifts when when speeding up
Tach_tech
5.7L HEMI
It's very unlikely changing a seal is going to cause any shifting issues, unless it was internal to the transmission. Most likely a separate issue. Have you checked the fluid level?
A
Alberta
It was the seal between to torque converter and transmission. I just got an oil change and they said all fluids are good but I will look for myself in the morning
RamCares
n/a
n/a
Let me know if you're in need of further assistance. - Kevin T, Social Connect Team
A
Alberta
Fluid in tranny is good what else should I try
