What gets me is the amount of people who believe the dealer or FCA about the 8 speed transmissions,being sealed for life,for one thing the transmission is not sealed,it has a vent to let air in and out,if it didn't,it would blow every seal when the transmission warmed up from the expansion of the air and fluid inside it,so if you live in a high humidity area,the air it sucks back in when it cools off,is the same high humidity air you're breathing,in other words moisture laden.But if you want to believe the theory it's sealed for life,go right ahead,i'm not so inclined to believe that one though.
If FCA told you the engine was sealed for life and didn't need an oil change,how many of you would believe them.BTW the transmission has wear pieces internally that contribute to oil contamination ,clutches and steels inside a transmission don't last forever
