2515x3jj
My 2-door driver's side switch is not working. The passenger side is ok. I removed the switch to jump the motor with an outside battery to make the window go up due to rain. Also checked the ground. All good. What I did find was the power wire has only 6 volts? to it. Strange ...... Any clue where the connector for the other side is that gets the power. I don't wish to pull the door harness out if I don't need to. Seems as though that's where the problem may be... thank you for reading my post....
