DIY Custome Grille / Valence
Trupiano
Registered User
6.7L CTD
This DIY is for making a custom grille and valence.
First you will need a 24x48 sheet of aluminum grille material. Whatever design/color you want. Many use gutter grill material but I don't like that stuff. I went to customcargrills.com - Custom Car & Truck Grills - Billet & Mesh Grill Inserts Bought mines for $120 shipped to the house.
Mesh cut in 2 pieces ; The grille and the valence
Took the grille off
Took the frame bars off
Mock Up of how it will look
Cut to fit, screws installed. Couple of the holes were stripper out, so I bent the mesh under them and wire tied it tight
Reinstalled and finished!
AND FOR THE VALENCE
Took the bumper off, 4 bolts 18mm socket, and it slides right forward and off. NOTE: MAKE SURE YOU HAVE AN EXTRA PERSON, OR A JACK TO REINSTALL THE BUMPER.
Removed the frame plates. 4 bolts on each side. 18mm socket
Installed the valence mesh. Cut, bent it to fit, and tucked it between the bumper frame and the plastic bumper cover.
Top row done, now for the bottom
All finished. Just reinstall the bumper with a friend or a jack.
Hemi badge reinstalled
All Finished!
OklaHemi
new age hemi
thats sick trup and easy. but do you have to pull the whole bumper off to do the bottom? i thought that piece was held on by 3 or 5 plastic screws?
Trupiano
Trupiano
Registered User
6.7L CTD
You might be able to slide the bumper cover off, but the screws/bolts looked hard to get to, and I wanted to install the pieces between the bumper cover and the bumper frame. So that wouldn't have worked for me. It literally took only minutes to removed the bumper. And only 5-8 to reinstall it. Plus I raised it up a lil with the floating bolts, so there isn't much gap between my headlights and the bumper.
The Valence mesh definately wont fit in there unless you remove wither the entire bumper and those plates, or the bumper cover.
OklaHemi
new age hemi
ah i got cha.
Trupiano
Trupiano
Registered User
6.7L CTD
Thanks guys! I actually tried taking that black step thing off the top of the bumper. It comes off easy, but there's like 20 square holes underneath it, that look like crap when it's off. Lame. Guess Ill have to wait till I get a different bumper.
OklaHemi
new age hemi
or paint it silver?
04SPORT
Elk Grove Village Illinois
What kind of screws did you use to hold it on? i would like to do this to my 04 but I have those plastic pins on mine, would those work?
2004hemi83
Does anyone produce a metal version of the fake (plastic) chrome grill or will I be having to fabricate one at work? I was thinking of making one out of stainless.
