Morimoto LED DRL Grille at Got Exhaust
Nick@GotExhaust
Supporting Vendor
SC
Product Details​
Can you see me now? With full LED headlights, tail tights, and off-road lights, you have no problem seeing at night, but that's not what this is all about. The XBG grille from Morimoto pairs high visibility with an OEM+ style and easy installation for a perfect way to finish off the front-end of your custom Ram truck.
Daytime Running Lights: Using the same automotive grade optics and Osram LEDs that come standard in Morimoto’s XB Evo LED headlights, the integrated DRL bars are insanely bright, easily visible even from afar in broad daylight! In fact, the daytime mode is so bright that the light bars will auto-dim in parking light, low beam, or high beam mode out of necessity to reduce glare at dusk or in the dark. These can be configured as either a white or amber daytime running light.
No Comparison: Put side-by-side during the day with other existing options in the aftermarket or anything you could DIY at home, and the quality, consistency, and intensity out of the Morimoto optics would make everything else look like a joke. If you are serious about the looks and performance of the parts you put on your truck, the XBG is the no brainer.
Customize It: The XBG grilles are highly customizable. Whether your truck is stacked with chrome or color-coordinated to the max, there is a XBG spec perfect for you. The front trim pieces can be removed with ease, painted (or wrapped), and then reassembled. Both the chrome and gloss black versions are ready to install right out of the box, but if you prefer to color match - we recommend going with the black base grille. Either way, the finished look is sure to impress!
Compatible: With all versions of the Dodge Ram 1500 trucks from 2013-2018, the XBG LED DRL grilles are extremely easy to install. They use all the stock mounting points and shouldn't take more than an hour to install. While the color/intensity is a perfect match for the Morimoto XB headlights, they'll also look great alongside a set of OEM or any other aftermarket headlights too.
Plug n Play: The XBG DRL bars have two intensities that automatically illuminate day and night based off the signals from the original headlight wiring that they're designed to connect with. The default setup intercepts the headlight signals from the truck. No modifications required.
Contact me for more information and availability
Nick@GotExhaust
Nick@GotExhaust
Supporting Vendor
SC
This grille looks factory but adds an aftermarket touch with the lighting. Also a very nice option to have it come in black or chrome!
Jacob Maguire
Pine Beach NJ
Hemi5.7
Amazing!!! Grill is a nice transition to the 5th gen styling, and coupled with a powered/LED (blade style) running board would be quite bitchn!
Kmiko
