canbus anti-flicker
  1. George Strickroth
    AlfaOBD & CANBUS Adapters
    On a 2019 RAM 1500 Classic with Quad Headlights, if I install something like the Headlight Revolution H11 Bulbs in the low beams, must I also install their CANBUS Adapter if I use AlfaOBD to set the front headlights to LED? I've asked this question on the HR Site, but have not gotten an answer...
  2. Boosted Motorsports
    How to install a third brake light CANBUS 921 bulb for dirt cheap!
    Found another set of CHEAP CANBUS compatible 921 bulbs. Heres how to install them and shows the bulbs I used. Only $9.99 for two and you only need one for the 3rd brake. No error or bulb out messages either!
  3. Wally Big Horn
    CougarMotor LED Headlight Bulbs All-in-One Conversion Kit - H11
    Has any used the CougarMotor LED Headlight Bulbs All-in-One Conversion Kit - H11 on a 2015 or newer Ram without a canbus anti-flicker module?
rockyj69
