diff rear end differential
  1. M
    2000 dodge 1500 4x4 9.25 diff
    I have a 2000 dodge 1500 4x4 with a 9.25 diff and when I change gears between park, reverse, and drive the rear end has a clunk. I have checked U joints and I don’t feel any play in them, when changing gears tho it looks like the pinion is moving in and out but the seal is not leaking. Any help...
  2. ArDavid318
    Rear diff at 200 degrees
    Hey guys I recently rebuilt my front and rear diff. I started hearing some gear hum during my high speed break in runs (around 65 it starts to humm). I installed 4.10 gears and heard that a little noise is OK… not sure if that’s true or not. With that I am past the short runs and are onto the...
  3. J
    Open diff to lsd
    I have a 17 sport with open diffs 3.21 gearing I wanna switch it out for some sort of lsd. What is the best route to go with this part numbers would help. When switched does in work in series with the existing traction control and such do I need any other parts as well?
rockyj69
