I have a 2013 ram 3.6 tradesman (flex fuel)
I cannot figure out why it continues to overheat. This is a run down of what I’ve done.
1. Check engine light came on and I got a code P0118 for temperature sensor
2. Replaced coolant temperature sensor. Problem still not fixed.
3. replaced...
So What I am towing is a travel trailer that weights about 7600 pounds. I started overheating when going uphill around Oklahoma so they arent that big! I am also reaching temps of 230 degrees on engine temp idling in the summer days! I have changed thermostat and fan clutch and did a flush on...
