gear swap
  1. J
    2008 ram 1500 3.55 to 4.56 ring gear swap carrier switch issue ?
    2008 dodge ram 1500 3.55 to 4.56 gear in rear with spicer 80754 carrier not clearing the pinion gear. I have the slightly beefier 06-08 9.25 housing. which if I a reading correctly will need ground down to clear the gear. what about the carrier? it hits when spinning ? from what I see guys...
  2. 14Fiveseven
    Regearing help needed
    Im trying to upgrade from the 3.21 gears currently on my 2014 ram 1500 2wd running 35s. I have found some oem 3.92 axles or a yukon 3.90 kit. I have found a kit on jeggs performance for $1,300 that includes everything I would need (I believe). Will provide link below. Is this a good kit and...
  3. Algunz
    3.22 Gear Swap to 3.92 Grocery List
    Here's the story: I'm currently running 35s on my 6in lift but want to upgrade to 37s.. My main concern is power loss and serious trans wear with adding the 37s.. my 35s weigh 69 lbs and the 37s I'm looking at are between 75-80 lbs, I doubt its a good idea to keep the 3.22s with the additional...
jimn
